For the first time in 7 years I see that there is a new, major release for the lame mp3 encoder, with lame 3.100 coming out on October 13th 2017.
There is an impressive list of bugfixes which I would like to have access to. How can I safely install this very newest version of lame on my Xenial Xerus 16.04 LTS system?
andrew.46
  • 39,359
The safest method that I have found that for the most part will not interfere with any system installation is to take a page from the FFmpeg trac site and install a local copy of lame.
The following single command gave me a working executable of the latest lame, safely installed in $HOME/bin:
mkdir -v $HOME/{lame_build,bin} && cd $HOME/lame_build && \
sudo apt-get install nasm build-essential && \
wget https://downloads.sourceforge.net/lame/lame-3.100.tar.gz && \
tar xvf lame-3.100.tar.gz && cd lame-3.100 && \
PATH="$HOME/bin:$PATH" \
./configure \
       --prefix="$HOME/lame_build" \
       --bindir=$HOME/bin \
       --enable-static \
       --disable-shared \
       --enable-nasm  && \
PATH="$HOME/bin:$PATH" make && \
make install
The detritus can then be removed with the following command:
rm -rfv $HOME/lame_build
The following now shows on my system:
andrew@corinth:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.3 LTS
Release:    16.04
Codename:   xenial
andrew@corinth:~$ lame --version | head -n 1
LAME 64bits version 3.100 (http://lame.sf.net)
andrew@corinth:~$
And all is well :)
andrew.46
  • 39,359
