I want to add Resume Media to VLC but I can't find the path ~/.local/share/vlc/lua/extensions/.
How do I find it using a file manager?
I found the folder where you would place it for all users but it won't let me paste it in. Probably a permissions thing. I don't know enough about the Linux file system to figure this out.
pomsky
  • 70,557
~/ stands for your "Home" folder. So you'll have to go to Home > .local > share > vlc > lua > extensions folder.
Open Files (or Nautilus, the file manager), it should open your home directory by default.
But you won't be able to see the .local folder there, it's hidden by default (as it starts with a .). You'll have to press ctrl+h first to unhide hidden folders. Then you'll see the .local folder there.
Then you'll be able to navigate to your target folder.
Once you're done you may press ctrl+h again to hide those folders starting with a ..
pomsky
  • 70,557
