I have recently read up on this forum on the meaning of "sda2" and "sdb", but I haven't found the way ubuntu names/handles flash drives yet.
Asked
Active
Viewed 148 times
Device names of flash drives
A flash drive can be connected
via USB
the device name is the same as for SATA drives,
/dev/sdxand partitions are named
/dev/sdxn
where
xis the device letter andnthe partition number, for example/dev/sda1via PCI
the device name is
/dev/mmcblkmand partitions are named
/dev/mmcblkmpn
where
mis the device number andnthe partition number, for example/dev/mmcblk0p1
Example with an SSD, HDD, USB pendrive and an SD card
lsblk
$ sudo lsblk -o model,name,fstype,size,label,mountpoint
MODEL NAME FSTYPE SIZE LABEL MOUNTPOINT
Samsung SSD 850 sda 232,9G
├─sda1 vfat 300M EFI /boot/efi
├─sda2 1M
├─sda3 ext4 100G root
└─sda4 swap 5G [SWAP]
00BEKT-00PVMT0 sdb 298,1G
├─sdb1 vfat 480M
├─sdb2 ext4 80G lubuntu-xenial64 /media/tester/lubuntu-xenial64
├─sdb3 swap 3,9G [SWAP]
├─sdb4 ext4 100G ubuntu-artful64x /
└─sdb5 ext4 113,7G ubuntu-artful64w /media/tester/ubuntu-artful64w
Extreme sdc 14,6G
├─sdc1 ntfs 6,7G usbdata /media/tester/usbdata1
├─sdc2 1M
├─sdc3 vfat 244M usbboot
├─sdc4 iso9660 948M Lubuntu 17.10 i386 /media/tester/Lubuntu 17.10 i386
└─sdc5 ext4 6,7G casper-rw /media/tester/casper-rw
mmcblk0 3,7G
├─mmcblk0p1 ntfs 661M usbdata /media/tester/usbdata
├─mmcblk0p2 1K
├─mmcblk0p3 vfat 122M usbboot /media/tester/usbboot
├─mmcblk0p4 iso9660 355M 9w-dus /media/tester/9w-dus
└─mmcblk0p5 ext4 2,6G persistence /media/tester/persistence
parted
$ sudo parted -ls
[sudo] password for tester:
Model: ATA Samsung SSD 850 (scsi)
Disk /dev/sda: 250GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 316MB 315MB fat32 boot, esp
2 316MB 317MB 1049kB
3 317MB 108GB 107GB ext4 root
4 244GB 249GB 5369MB linux-swap(v1)
Model: WDC WD32 00BEKT-00PVMT0 (scsi)
Disk /dev/sdb: 320GB
Disk Flags:
1 33,6MB 537MB 503MB fat32 EFI System Partition boot, esp
2 537MB 86,4GB 85,9GB ext4
4 86,4GB 194GB 107GB ext4
5 194GB 316GB 122GB ext4
3 316GB 320GB 4161MB linux-swap(v1)
Model: SanDisk Extreme (scsi)
Disk /dev/sdc: 15,7GB
Disk Flags:
2 1049kB 2097kB 1049kB primary bios_grub
3 2097kB 258MB 256MB fat32 primary boot, esp
4 258MB 1252MB 994MB primary
5 1252MB 8473MB 7221MB ext2 primary
1 8473MB 15,7GB 7221MB ntfs primary msftdata
Model: SD SD04G (sd/mmc)
Disk /dev/mmcblk0: 3965MB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
3 2097kB 130MB 128MB primary fat32 boot
4 130MB 502MB 372MB primary
2 502MB 3272MB 2769MB extended lba
5 503MB 3272MB 2768MB logical ext2
1 3272MB 3965MB 693MB primary ntfs
sudodus
- 47,684
