I'm using Ubuntu 17.04 in my laptop.
free -m command gave me the following output after i logged in to my PC and ran this command.
ubuntu@ubuntu-pc:~$ free -m
              total        used        free      shared  buff/cache   available
Mem:           3865        1527        1171         249        1167        1862
Swap:          2047           0        2047
How can i calculate the memory usage of Desktop environment(Unity) after deducting the buffer and cache.
Answers like this are bit confusing.
Rooney
  • 975
These tools show the memory usage of all running processes (for example when you are running Ubuntu with Unity, but no particular application program running).
free
I am also using
free -m  # Display the amount of memory in megabytes.
and I think the column 'used' is useful (no pun intended).
The output of free is explained in the manual
man free
DESCRIPTION free displays the total amount of free and used physical and swap memory in the system, as well as the buffers and caches used by the kernel. The information is gathered by parsing /proc/mem‐ info. The displayed columns are:
total
Total installed memory (MemTotal and SwapTotal in /proc/meminfo)
used
Used memory (calculated as total - free - buffers - cache)
free
Unused memory (MemFree and SwapFree in /proc/meminfo)
shared
Memory used (mostly) by tmpfs (Shmem in /proc/meminfo, available on kernels 2.6.32, displayed as zero if not available)
buffers
Memory used by kernel buffers (Buffers in /proc/meminfo)
cache
Memory used by the page cache and slabs (Cached and Slab in /proc/meminfo)
buff/cache
Sum of buffers and cache
available
Estimation of how much memory is available for starting new applications, without swapping. Unlike the data provided by the cache or free fields, this field takes into account page cache and also that not all reclaimable memory slabs will be reclaimed due to items being in use (MemAvailable in /proc/meminfo, available on kernels 3.14, emulated on kernels 2.6.27+, otherwise the same as free)
top
top will show the same (or almost the same) result (tested in 16.04 LTS), (but in older versions the output of top was more difficult to match to the output of free).
htop, more user friendly
You will get a similar result as 'used' with htop installed with
sudo apt install htop
sudodus
  • 47,684
