My software updater got stuck while installing the linux kernel 4.10.0-38. When I killed the process and run sudo dpkg --configure -a, I got:
Setting up linux-headers-4.10.0-38-generic (4.10.0-38.42) ...
Examining /etc/kernel/header_postinst.d.
run-parts: executing /etc/kernel/header_postinst.d/dkms 4.10.0-38-generic /boot/vmlinuz-4.10.0-38-generic
And then nothing happened for a very long time. When I press control + C, I got:
Failed to process /etc/kernel/header_postinst.d at /var/lib/dpkg/info/linux-headers-4.10.0-38-generic.postinst line 110.
dpkg: error processing package linux-headers-4.10.0-38-generic (--configure):
subprocess installed post-installation script returned error exit status 2
Setting up linux-image-4.10.0-38-generic (4.10.0-38.42) ...
update-initramfs: deferring update (hook will be called later)
The link /initrd.img is a dangling linkto /boot/initrd.img-4.10.0-38-generic
vmlinuz(/boot/vmlinuz-4.10.0-38-generic
) points to /boot/vmlinuz-4.10.0-38-generic
(/boot/vmlinuz-4.10.0-38-generic) -- doing nothing at /var/lib/dpkg/info/linux-image-4.10.0-38-generic.postinst line 491.
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.10.0-38-generic /boot/vmlinuz-4.10.0-38-generic
run-parts: executing /etc/kernel/postinst.d/dkms 4.10.0-38-generic /boot/vmlinuz-4.10.0-38-generic
And it got stuck again. Then I press control + C again, I got:
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-4.10.0-38-generic.postinst line 1052.
dpkg: error processing package linux-image-4.10.0-38-generic (--configure):
dpkg: dependency problems prevent configuration of linux-headers-generic:
linux-headers-generic depends on linux-headers-4.10.0-38-generic; however:
Package linux-headers-4.10.0-38-generic is not configured yet.
dpkg: error processing package linux-headers-generic (--configure):
dependency problems - leaving unconfigured
Then I run sudo dpkg --config -a and got:
The following packages have been unpacked but not yet configured.
They must be configured using dpkg --configure or the configure
menu option in dselect for them to work:
linux-headers-generic Generic Linux kernel headers
The following packages are only half configured, probably due to problems
configuring them the first time. The configuration should be retried using
dpkg --configure <package> or the configure menu option in dselect:
linux-headers-4.10.0-38-generic Linux kernel headers for version 4.10.0 on 64
linux-image-4.10.0-38-generic Linux kernel image for version 4.10.0 on 64 bit
Now I can't install anything using apt, because whenever I use apt, it will try to configure the kernel and get stuck again. I also need to manually select kernel every time I boot my computer because the default 4.10.0-38 kernel didn't work. How can I fix that?
I tried this solution by replacing all 4.4.0-38 in commands with 4.10.0-38, but it didn't work.
Now my /var/lib/dpkg/status is:
Package: linux-image-extra-4.10.0-38-generic
Status: deinstall ok config-files
Priority: optional
Section: kernel
Installed-Size: 151751
Maintainer: Ubuntu Kernel Team <kernel-team@lists.ubuntu.com>
Architecture: amd64
Source: linux
Version: 4.10.0-38.42
Depends: linux-image-4.10.0-38-generic, crda | wireless-crda
P.S. I'm using nvidia driver and have VirtualBox installed. However, I don't have the /etc/kernel/postinst.d/vboxadd file.
