I am running Kubuntu 14.4 and I want to scan with my Brother DCP-J140W, which does not work. I installed
sudo apt-get install sane xsane xsane-common sane-utils libsane libsane-common libsane-dbg libsane-dev libsane-extras libsane-extras-common libsane-extras-dbg libsane-extras-dev
as suggested in Brother DCP-J140W does not scan (brscan4, USB connected)
I went to http://support.brother.com/g/b/downloadlist.aspx?c=us&lang=en&prod=dcpj140w_all&os=128 and installed
  • Scanner driver 64bit (deb package)
  • Scan-key-tool 64bit (deb package)
with --force-all and then I ran
brscan-skey
When I check whether the connection is established I get
$ sudo scanimage -L
device `brother4:bus2;dev1' is a Brother DCP-J140W USB scanner
$ brscan-skey -l
DCP-J140W         : brother4:bus2;dev1  : USB                  Active
which looks good. When I command $ xsane a window opens which says it is searching for devices but then outputs
Error when opening the device 'brother4:bus2;dev': Unvalid argument
When I go to my scanner and
  1. Press "Scanner"
  2. Choose scan to image
  3. Press "Start"
I get "PC-Connection" on the display but nothing happens. What do I do?
Make42
  • 439
It seems the main issue was that I need to start brscan-skey as the right user. What one needs to do is start it via
$ sudo su
# brscan-skey
Also I did some mistakes when editing the shell scripts (although this is not directly related to the question). To summarize, the actual command is implemented in /opt/brother/scanner/brscan-skey/brscan-skey. In /opt/brother/scanner/brscan-skey/brscan-skey-0.2.4-0.cfg it is defined which script is started when which option is chosen on the scanner. The respective scripts are in /opt/brother/scanner/brscan-skey/script/, so one needs to edit them if one wants to change settings. A description is mentioned e.g. in https://wiki.ubuntuusers.de/Scanner/Brother/Scankey-Tool/#Scankey-Tool-Optimierung
Make42
  • 439
