when I launch either Spyder3 or backintime, they now blink briefly in the unity launcher but never actually show up.
(see image). How to fix this? They both used to work like a week ago.
Edit:
Sure, here are two:
~$ backintime
Traceback (most recent call last):
  File "/usr/share/backintime/common/backintime.py", line 23, in <module>
    import config
  File "/usr/share/backintime/common/config.py", line 31, in <module>
    import tools
  File "/usr/share/backintime/common/tools.py", line 43, in <module>
    import dbus
  File "/usr/lib/python3/dist-packages/dbus/__init__.py", line 81, in <module>
    import dbus.exceptions as exceptions
AttributeError: module 'dbus' has no attribute 'exceptions'
Error in sys.excepthook:
  File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 63, in apport_excepthook
    from apport.fileutils import likely_packaged, get_recent_crashes
  File "/usr/lib/python3/dist-packages/apport/__init__.py", line 5, in <module>
    from apport.report import Report
  File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in <module>
    import apport.fileutils
  File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in <module>
    from apport.packaging_impl import impl as packaging
  File "/usr/lib/python3/dist-packages/apport/packaging_impl.py", line 23, in <module>
    import apt
  File "/usr/lib/python3/dist-packages/apt/__init__.py", line 23, in <module>
    import apt_pkg
ModuleNotFoundError: No module named 'apt_pkg'
Original exception was: Traceback (most recent call last): File "/usr/share/backintime/common/backintime.py", line 23, in <module> import config File "/usr/share/backintime/common/config.py", line 31, in <module> import tools File "/usr/share/backintime/common/tools.py", line 43, in <module> import dbus File "/usr/lib/python3/dist-packages/dbus/init.py", line 81, in <module> import dbus.exceptions as exceptions AttributeError: module 'dbus' has no attribute 'exceptions'
and
~$ spyder3
  File "/usr/local/lib/python3.6/dist-packages/spyder/utils/external/lockfile.py", line 150, in lock
    symlink(str(os.getpid()), self.name)
FileExistsError: [Errno 17] File exists: '6240' -> '/home/me/.config/spyder-py3/spyder.lock'
During handling of the above exception, another exception occurred:
Traceback (most recent call last): File "/usr/local/lib/python3.6/dist-packages/spyder/utils/external/lockfile.py", line 177, in lock kill(int(pid), 0) ProcessLookupError: [Errno 3] No such process
Traceback (most recent call last): File "/usr/local/lib/python3.6/dist-packages/spyder/app/start.py", line 118, in main lock_created = lock.lock() File "/usr/local/lib/python3.6/dist-packages/spyder/utils/external/lockfile.py", line 196, in lock rmlink(self.name) PermissionError: [Errno 13] Permission denied: '/home/me/.config/spyder-py3/spyder.lock'
Traceback (most recent call last): File "/usr/local/lib/python3.6/dist-packages/qtpy/init.py", line 148, in <module> from PySide import version as PYSIDE_VERSION # analysis:ignore ModuleNotFoundError: No module named 'PySide'
Traceback (most recent call last): File "/usr/local/bin/spyder3", line 11, in <module> sys.exit(main()) File "/usr/local/lib/python3.6/dist-packages/spyder/app/start.py", line 138, in main from spyder.app import mainwindow File "/usr/local/lib/python3.6/dist-packages/spyder/app/mainwindow.py", line 49, in <module> requirements.check_qt() File "/usr/local/lib/python3.6/dist-packages/spyder/requirements.py", line 39, in check_qt import qtpy File "/usr/local/lib/python3.6/dist-packages/qtpy/init.py", line 154, in <module> raise PythonQtError('No Qt bindings could be found') qtpy.PythonQtError: No Qt bindings could be found Error in sys.excepthook: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 63, in apport_excepthook from apport.fileutils import likely_packaged, get_recent_crashes File "/usr/lib/python3/dist-packages/apport/init.py", line 5, in <module> from apport.report import Report File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in <module> import apport.fileutils File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in <module> from apport.packaging_impl import impl as packaging File "/usr/lib/python3/dist-packages/apport/packaging_impl.py", line 23, in <module> import apt File "/usr/lib/python3/dist-packages/apt/init.py", line 23, in <module> import apt_pkg ModuleNotFoundError: No module named 'apt_pkg'
Original exception was: Traceback (most recent call last): File "/usr/local/lib/python3.6/dist-packages/spyder/utils/external/lockfile.py", line 150, in lock symlink(str(os.getpid()), self.name) FileExistsError: [Errno 17] File exists: '6240' -> '/home/me/.config/spyder-py3/spyder.lock'
user2413
  • 14,957
Errors with backintime may we fixed by reinstalling it with dependencies:
sudo apt-get install --reinstall backintime-qt4 libqt4-designer libqt4-help libqt4-opengl libqt4-scripttools libqt4-svg libqt4-test libqtassistantclient4 libqtwebkit4 python3-dbus python3-dbus.mainloop.qt python3-keyring python3-pyqt4 python3-secretstorage python3-sip
N0rbert
  • 103,263
