I'd like to verify whether my server set Hyper-threading, and the way to it.
lscpu shows Thread per core is "2"
sudo dmidecode shows HTT (Multi-threading).
I expected HTT (Hyper-threading technology), if Hyper-threading is enabled.
Please let me know to check Hyper-threading state and to make enable Hyper-threading.
And lshw -c network is different capacity 1Gbit/s with ethtool eth0 10GB/s Why are those different? how to know correct network bandwidth? Regards,
Hans Lee
  • 121
cat /proc/cpuinfo |grep 'cpu cores' -- gives you number of real cores available
cat /proc/cpuinfo |grep processor |wc -l -- gives you number of 'fake' cores
If the numbers are the same, then you don't have HT enabled. this may not work on newer AMD processors but does on all manner of Intel processors from Xeon to i5
Enabling HT depends on your server/motherboard/bios settings.
Your network card speeds are a mixed bag - you should provide a screen dump. Best guess, your network card is 10Gbit capable, but your network is not. It could be a switch that is not capable or connecting cable, or other.
sergtech
  • 513
