For some reason I cannot stop the GRUB menu from appearing every boot on my Ubuntu 14.04.05 installation.
I have ensured that my /etc/default/grub file has GRUB_HIDDEN_TIMEOUT=0 and GRUB_TIMEOUT=0 and I then ran sudo update-grub, to no avail.
The version on the GRUB menu says GNU GRUB version v2.02~beta2-9ubuntu1.14 if that helps at all, and if there's anything else that may be helpful just ask and I'll respond with it.
I searched around and couldn't find much on this topic.
Edit since OP wasn't clear enough:
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
Those are the pertinent settings currently in my /etc/default/grub, and I run sudo update-grub, which completes successfully it seems.
However, the GRUB menu still appears at boot.
Final edit for posterity:
None of the traditional solutions worked, I tried regenerating the grub file after ensuring that /etc/default/grub contained the proper information, to no avail.
What finally worked for me is entering the command:
grub-editenv create
as documented in this answer.
Open /etc/default/grub with your favorite text editor. Make sure the following lines are not commented out or add them if they don't exist.
Finally run :
sudo update-grub
George Udosen
  • 37,534
Michael
  • 533
