I have upgraded to artful recently and cannot install r-recommended any longer. I keep getting this error message:
user@box:~$ sudo apt install r-recommended
[sudo] password for user:
Reading package lists... Done
Building dependency tree
 r-recommended : Depends: r-cran-boot (>= 1.2.19) but it is not going to be installed
user@box:~$
Nonetheless, https://cran.r-project.org/bin/linux/ubuntu/artful/ is already available.
Edit: As asked by @muru in the comments, the output from sudo apt-get update plus the output from sudo apt-get upgrade were
user@box:~$ sudo apt update
Hit:1 http://download.virtualbox.org/virtualbox/debian zesty InRelease
Ign:2 http://dl.google.com/linux/chrome/deb stable InRelease
Ign:3 https://cran-r.c3sl.ufpr.br/bin/linux/ubuntu artful/ InRelease
Hit:4 http://dl.google.com/linux/chrome/deb stable Release
Hit:5 https://cran-r.c3sl.ufpr.br/bin/linux/ubuntu artful/ Release
Hit:8 http://archive.ubuntu.com/ubuntu artful InRelease
Hit:9 http://archive.canonical.com/ubuntu artful InRelease
Hit:10 http://archive.ubuntu.com/ubuntu artful-updates InRelease
Hit:11 http://archive.ubuntu.com/ubuntu artful-backports InRelease
Hit:12 http://archive.ubuntu.com/ubuntu artful-security InRelease
All packages are up to date.
user@box:~$ sudo apt upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
user@box:~$
For users who come across this error in a different setting.
I had this on 18.04 after upgrading from 16.04.
I had another mirror on the 16.04 for cran. After the upgrade I had issues upgrading r-recommended with this same sort of output.
Once I had removed the source list, in my case cran.mirror.ac.za, the upgrade still didn't work with the output:
 r-cran-boot : Depends: r-api-3.4
 r-cran-class : Depends: r-api-3.4
 r-cran-cluster : Depends: r-api-3.4
 r-cran-codetools : Depends: r-api-3.4
 r-cran-foreign : Depends: r-api-3.4
 r-cran-kernsmooth : Depends: r-api-3.4
 r-cran-lattice : Depends: r-api-3.4
 r-cran-mass : Depends: r-api-3.4
 r-cran-matrix : Depends: r-api-3.4
 r-cran-mgcv : Depends: r-api-3.4
 r-cran-nlme : Depends: r-api-3.4
 r-cran-nnet : Depends: r-api-3.4
 r-cran-rpart : Depends: r-api-3.4
 r-cran-spatial : Depends: r-api-3.4
 r-cran-survival : Depends: r-api-3.4
I had to apt-get remove r-base-core, apt-get clean and then I could install r-recommended without an issue.
I think the issue was that the depended on package, r-base-core was installed from the other repo, and not automatically upgraded with the Ubuntu one.
This may actually have been the OP's situation, or can present the same in any case, so I thought may be a helpful answer.
There appears to be a broken dependency for r-cran-boot. Specifically, it depends on r-api-3, which no longer exists, having been changed to r-api-3.4.
sudo aptitude full-upgrade
The following packages will be upgraded:
  r-cran-boot{b}
1 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 618 kB of archives. After unpacking 0 B will be used.
 r-cran-boot : Depends: r-api-3 which is a virtual package and is not provided by any available package
The following actions will resolve these dependencies:
 Keep the following packages at their current version:
1)     r-cran-boot [1.3-20-1build1 (artful, now)]
Accept this solution? [Y/n/q/?]
I'll try to submit a bug report presently.
Update: the package maintainer appears to have fixed the problem. I am able to upgrade without getting a dependency error.
Indeed, as indicated by Paul Stodghill in his answer, installing with aptitude will do the trick as long as you know that it will propose first to install nothing -- one useless proposal you need to decline -- for, just then, it will propose to install r-cran-boot anyway with the unmet dependency on r-api-3.4, as seen in this output:
user@box:~$ sudo aptitude install r-recommended
The following NEW packages will be installed:
  cdbs{a} dh-translations{a} intltool{a} libblas-dev{a} liblapack-dev{a} libncurses5-dev{a} libreadline-dev{a} libtinfo-dev{a} python-pkg-resources{a} python-scour{a}
  python-six{a} r-base-core{a} r-base-dev{a} r-cran-boot{ab} r-cran-class{a} r-cran-cluster{a} r-cran-codetools{a} r-cran-foreign{a} r-cran-kernsmooth{a}
  r-cran-lattice{a} r-cran-mass{a} r-cran-matrix{a} r-cran-mgcv{a} r-cran-nlme{a} r-cran-nnet{a} r-cran-rpart{a} r-cran-spatial{a} r-cran-survival{a} r-doc-html{a}
  r-recommended
0 packages upgraded, 30 newly installed, 0 to remove and 0 not upgraded.
Need to get 43.5 MB of archives. After unpacking 78.9 MB will be used.
 r-cran-boot : Depends: r-api-3 which is a virtual package, provided by:
                        - r-base-core (3.4.2-2zesty), but 3.4.2-2artful4 is to be installed
1)     r-cran-boot [Not Installed]
2)     r-recommended [Not Installed]
     Leave the following dependencies unresolved:
3)     r-base-core recommends r-recommended
Accept this solution? [Y/n/q/?] n
     Install the following packages:
1)     r-cran-boot [1.3-20-1build1 (artful)]
Accept this solution? [Y/n/q/?] y
  python-six{a} r-base-core{a} r-base-dev{a} r-cran-boot{a} r-cran-class{a} r-cran-cluster{a} r-cran-codetools{a} r-cran-foreign{a} r-cran-kernsmooth{a}
  r-recommended
Do you want to continue? [Y/n/?] y
Get: 1 https://cloud.r-project.org/bin/linux/ubuntu artful/ r-base-core 3.4.2-2artful4 [23.2 MB]
Get: 2 https://cloud.r-project.org/bin/linux/ubuntu artful/ r-base-dev 3.4.2-2artful4 [4414 B]
Setting up r-cran-rpart (4.1-11-1build1) ...
Setting up r-recommended (3.4.2-2artful4) ...
Current status: 1 (+1) upgradable.
user@box:~$
