I had Ubuntu 14.04 and Windows 10 on my laptop. I upgraded the Ubuntu to 16.04, but it is not working fine. Instead of fixing everything in this installation, is there a way to reset everything in Ubuntu to have like a fresh installation of 16.04, and keep my home folder and also the Windows on the laptop? If not, can I reset as many packages as possible to 16.04 default ones?
The home partition is different from the Ubuntu system partition.
Abaris
  • 23
Here you have the necessary knowledge: https://askubuntu.com/a/270045/752939
If you have a dedicated partition for /home:
launch the installer when it comes to the choice of disk and partitions, choose "other" and then, manually select the partition for / and /home; check that the installer will format only the / partition, and not the /home
Rey Fox
  • 41
I have tried Resetter for your exact issue. If you haven't modified system files yourself which causes problems and just use the automatic reset and it'll take care of it for you.
answerSeeker
  • 901
  • 26
