From https://wiki.ubuntu.com/SELinux
Warning
The Ubuntu-specific "selinux" and "selinux-policy-ubuntu"
packages documented here have not received much attention since
Karmic, and appear to be effectively broken in Precise.
If you wish to
use SELinux in Ubuntu, the "selinux-basics" and
"selinux-policy-default" packages from Debian are still being actively
maintained. Documentation relevant to those packages can be found at
http://wiki.debian.org/SELinux
There are selinux packages in Ubuntu you certainly can try, however, as they are poorly supported, undocumented, and I would not expect them to work out of the box. More likely than not they are the same packages as are available in the Debian repos, but they may have been modified for Ubuntu, and certainly worth a try before you go to pinning. Use the advice on the Debian selinux wiki page without the debian repos first.
If the Ubuntu packages fail, you may then wish to then try the advice of the Ubuntu selinux wiki page and install / configure selinux using the Debian packages, see ...
https://wiki.debian.org/SELinux
You go to the Debian setup page - https://wiki.debian.org/SELinux/Setup
Get the default policy and the basic set of SELinux utilities by
running apt-get install selinux-basics selinux-policy-default auditd
Note, you would have to install them from the appropriate debian repositories or download the .deb. To do so you will have to add the debian repositories, and use pinning.
Here is a listing of versions of Ubuntu and Debian you can use for pinning.
What Debian version are the different Ubuntu versions based on?
https://help.ubuntu.com/community/PinningHowto
Also note, from the same Debian page:
If using Ubuntu, download this _load_selinux_policy script (this is a
slightly modified version of the script included in the Ubuntu
'selinux' package), place it in
/usr/share/initramfs-tools/scripts/init-bottom/ then run
update-initramfs -u (Upstart in Debian loads the SELinux policy
automatically, but Upstart in Ubuntu does not. See
https://bugs.launchpad.net/upstart/+bug/595774)
The bug may or may not be fixed https://bugs.launchpad.net/upstart/+bug/595774 (marked as fix released).
Then continue with
Run selinux-activate to configure GRUB and PAM and to create
/.autorelabel
Reboot, it will take a while to label the filesystems on
boot and then it will automatically reboot a second time when that is
complete.
Run check-selinux-installation to check that everything has
been setup correctly and to catch common SELinux problems. (Note: in
wheezy the warning about /etc/pam.d/login is a false positive)
Also from https://wiki.debian.org/SELinux/Issues
Graphical/Desktop installs of Debian are not heavily tested with
selinux, so you might run into quite some issues.
Assuming you are NOT RUNNING a graphical desktop you may do alright. If you are running a graphical desktop, expect problems. Debugging selinux policy on Ubuntu will be poorly supported at best.
Also see outstanding bugs before you install selinux - https://bugs.debian.org/cgi-bin/pkgreport.cgi?repeatmerged=no&src=refpolicy
Also I would anticipate problems due to differences between Ubuntu and Debian, depending on versions of each, systemd, upstart, and MIR may all conflict or not have a selinux policy from Debian.
Good luck with all that =) I personally know only one person who was able to use selinux successfully on Ubuntu, and it was a short run.
Parting advice
Ubuntu uses Apparmor and I highly advise you continue with apparmor and NOT go with selinux.
If you wish to go to selinux on Ubuntu, do so on a test machine first and expect problems.
If you are not familiar with selinux and debugging policy, you will likely need to do a lot of reading. Both RHEL selinux and Fedora selinux maintain documentation you can use as a reference.
If you must use selinux I HIGHLY ADVISE you use a .rpm system such as Centos, RHEL, or Fedora.
