I am using XUbuntu 17.10 and i have created a wifi hotspot, the problem is i want to use the hotspot for samba and other things that don't require an internet connection. how do i create a wifi hotspot that doesn't share my internet connection? is this even possible?
A simple solution is to use create_ap. From their site:
create_ap is a tool that helps you create an open, or encrypted AP at any channel, hide your SSID, disable communication between clients (client isolation), IEEE 802.11n & 802.11ac support, Internet sharing methods: NATed or Bridged or None (no Internet sharing)
For your case you want to create an AP with the linux pc without sharing the internet from your dongle to clients, but can do other Lan stuff, like file sharing.
Your wifi card needs to support creating AP
Install some packages:
sudo apt install util-linux bash procps hostapd iproute2 iw haveged net-tools dnsmasq iptablesGet the
create_appackage. From the terminal dogit clone https://github.com/oblique/create_ap cd create_ap sudo make installAfter installation, check the name of your modem and wifi card with
ifconfig(deprecated) or:iwconfigthe wifi card usually is
wlan0orwlp2s0and usb modem iseth0. yours might be differentNow start hotspot from your linux without internet:
sudo create_ap -n wlp2s0 MyAccessPoint
You can then connect clients. Your internet would not be shared but you can do samba and other things without internet
- 17,371
- 2,044
Here is a script that will create Hotspot but not share the Ethernet Internet with the WiFi devices. You will have to change the network interface name according to your system.
Type ip link to find them. Also, make sure you have installed dnsmasq and hostapd.
sudo apt-get install ifconfig dnsmasq hostapd
Before running the script you will have to stop any Network Management Tool which is controlling WiFi.
eth-to-wifi-route.sh
#!/bin/bash
# Share Eth with WiFi Hotspot
# This script is created to work with Raspbian Stretch
# but it can be used with most of the distributions
# by making few changes.
# Make sure you have already installed `dnsmasq` and `hostapd`
# Please modify the variables according to your need
# Don't forget to change the name of network interface
# Check them with `ifconfig`
ip_address="192.168.2.1"
netmask="255.255.255.0"
dhcp_range_start="192.168.2.2"
dhcp_range_end="192.168.2.100"
dhcp_time="12h"
eth="eth0" # replace it with Huawei 3G Modem interface
wlan="wlan0"
ssid="Arpit-Raspberry"
psk="arpit1997"
sudo rfkill unblock wlan &> /dev/null
sleep 2
#sudo iptables -F
#sudo iptables -t nat -F
#sudo iptables -t nat -A POSTROUTING -o $eth -j MASQUERADE
#sudo iptables -A FORWARD -i $eth -o $wlan -m state --state RELATED,ESTABLISHED -j ACCEPT
#sudo iptables -A FORWARD -i $wlan -o $eth -j ACCEPT
#sudo sh -c "echo 1 > /proc/sys/net/ipv4/ip_forward"
sudo ifconfig $wlan $ip_address netmask $netmask
sudo ip route del 0/0 dev $wlan &> /dev/null
a=`route | awk "/${eth}/"'{print $5+1;exit}'`
sudo route add -net default gw $ip_address netmask 0.0.0.0 dev $wlan metric $a
echo -e "interface=$wlan \n\
bind-interfaces \n\
server=8.8.8.8 \n\
domain-needed \n\
bogus-priv \n\
dhcp-range=$dhcp_range_start,$dhcp_range_end,$dhcp_time" > /etc/dnsmasq.conf
sudo systemctl restart dnsmasq
echo -e "interface=$wlan\n\
driver=nl80211\n\
ssid=$ssid\n\
hw_mode=g\n\
ieee80211n=1\n\
wmm_enabled=1\n\
macaddr_acl=0\n\
auth_algs=1\n\
ignore_broadcast_ssid=0\n\
wpa=2\n\
wpa_key_mgmt=WPA-PSK\n\
wpa_passphrase=$psk\n\
rsn_pairwise=CCMP" > /etc/hostapd/hostapd.conf
sudo systemctl restart hostapd
sudo systemctl status hostapd &> /dev/null
if [ "$?" != 0 ];then
echo "Some Network Management tool is running, which is stopping"
echo "hostapd to be configured."
echo "Please stop that and again run the script."
fi
I have commented the iptable and packet forwarding commands. If anytime you need to give internet to the devices just uncomment them.
Run the script
sudo bash eth-to-wifi-route.sh
Source: eth-to-wifi-route.sh
- 17,371
- 179
- 6
