I'd like to remove the need for the user to type a password multiple times for a bash script that runs sudo commands. How can I loop for password until something like sudo echo returns 0, and then store the password in a variable to use script-wide?
- 119,640
- 188
- 2
- 9
It is certainly possible to remove the need to type sudo password for specific commands or even whole scripts.
Your suggested path of storing the password in a local variable in the script is rather unwise. Anyone with read rights to /proc/<pid>/environ can read the local variables. Anyone who gains read access to a script, with hard coded credentials, could use those credentials to escalate privileges to root and own your system. On a single user system this is still unwise as there are increasing remote attacks targeting Linux users.
Without the specifics of your script I can only advise you to read Ubuntu Community Wiki - Sudoers. Then modify your sudoers file by running sudo visudo to add the specific commands to the file.
Likely you should add two lines one to add a command alias, and the second to authorize users to run those commands.
An example of allowing specific user ie, bob, to run selected shutdown commands without a password.
Cmnd_Alias SHUTDOWN_CMDS = /sbin/poweroff, /sbin/halt, /sbin/reboot
bob ALL=(ALL) NOPASSWD: SHUTDOWN_CMDS
The following script is an example of how to include in a script the ability to install, uninstall, or edit the example lines in /etc/sudoers.
#!/bin/bash
#Set Script Name variable
SCRIPT=`basename ${BASH_SOURCE[0]}`
#Initialize variables to default values.
OPT_i=i
OPT_u=u
OPT_e=e
OPT_m=m
#Set fonts for Help.
NORM=`tput sgr0`
BOLD=`tput bold`
REV=`tput smso`
#Help function
function HELP {
echo -e \\n"Help documentation for ${BOLD}${SCRIPT}.${NORM}"\\n
echo -e "${REV}Basic usage:${NORM} ${BOLD}$SCRIPT file.ext${NORM}"\\n
echo "Command line switches are optional. The following switches are recognized."
echo "${REV}-1${NORM} --Installs lines in /etc/sudoers to allow script to be run without entering password multiple times."
echo "${REV}-u${NORM} --Unistalls lines in /etc/sudoers."
echo "${REV}-e${NORM} --Launces visudo to edit /etc/sudoers."
echo "${REV}-m${NORM} --Launces main."
echo -e "${REV}-h${NORM} --Displays this help message. No further functions are performed."\\n
exit 1
#Install function
function INSTALL {
echo "launching Install"
echo -e '#script_append'\\n'Cmnd_Alias SHUTDOWN_CMDS = /sbin/poweroff, /sbin/halt, /sbin/reboot'\\n'bob ALL=(ALL) NOPASSWD: SHUTDOWN_CMDS' | sudo EDITOR='tee -a' visudo
#Unnstall function
function UNINSTALL {
echo "launching uninstall"
bash -c 'printf ",g/^#script_append$/d\nw\nq\n" | sudo EDITOR='ed' visudo'
bash -c 'printf ",g/^Cmnd_Alias.*reboot$/d\nw\nq\n" | sudo EDITOR='ed' visudo'
bash -c 'printf ",g/^bob ALL=(ALL) NOPASSWD: SHUTDOWN_CMDS$/d\nw\nq\n" | sudo EDITOR='ed' visudo'
#Main function
function MAIN {
echo "launching editor via main"
sudo visudo
#Check the number of arguments. If none are passed, print help and exit.
NUMARGS=$#
echo -e \\n"Number of arguments: $NUMARGS"
if [ $NUMARGS -eq 0 ]; then
HELP
fi
### Start getopts code ###
#Parse command line flags
#If an option should be followed by an argument, it should be followed by a ":".
#Notice there is no ":" after "h". The leading ":" suppresses error messages from
#getopts. This is required to get my unrecognized option code to work.
while getopts ":iuemh" FLAG; do
case "${FLAG}" in
i) #set option "i"
OPT_i=${OPTARG}
echo "-i used: $OPTARG"
if sudo grep -q '#script_append' /etc/sudoers
then
echo "Sudoers apperes to have already been installed"
exit
else
INSTALL
fi
u) #set option "u"
OPT_u=$OPTARG
echo "-u used: $OPTARG"
UNINSTALL
e) #set option "e"
OPT_e=$OPTARG
echo "-e used: $OPTARG"
sudo visudo
m) #set option "m"
OPT_m=$OPTARG
echo "-m used: $OPTARG"
MAIN
h) #show help
HELP
\?) #unrecognized option - show help
echo -e \\n"Option -${BOLD}$OPTARG${NORM} not allowed."
HELP
#If you just want to display a simple error message instead of the full
#help, remove the 2 lines above and uncomment the 2 lines below.
#echo -e "Use ${BOLD}$SCRIPT -h${NORM} to see the help documentation."\\n
#exit 2
esac
done
shift $((OPTIND-1)) #This tells getopts to move on to the next argument.
### End getopts code ###
- 1,979
My current approach that seems to be working is as follows:
read_sudo_pwd() {
read -s -p "[sudo] password for $USER: " sudo_pwd
until (echo $sudo_pwd | sudo -S echo '' 2>/dev/null)
do
echo -e '\nSorry, try again.'
done
read_sudo_pwd
echo $sudo_pwd | sudo -S echo 'Hello'
echo $sudo_pwd | sudo -S echo 'World'
- 188
- 2
- 9
