I’m using Ubuntu 17.04 on my laptop. I’m not sure how the issue started since it is by no means a fresh install. I’m unable to resolve any DNS hostnames via browser or telnet. I’ve confirmed this on the laptop in question over multiple WiFi networks. I also confirmed that other devices on the same network are not experiencing this issue. I can ping any external IP address (e.g. 8.8.8.8) just fine. I can also visit websites by typing the IP address into the browser.
Things I have tried:
I tried running
sudo dpkg-reconfigure resolvconfto no effect.I’ve also tried going into the network settings for the WiFi network and changing the Method to “Automatic (DHCP) addresses only”, then manually adding DNS server addresses.
I also tried adding a
supersede domain-name-serversline in myetc/dhcp/dhclient.conffile which did not resolve the issue either.I even manually edited my
/etc/resolv.confto replace my nameserver with 8.8.8.8.Adding dns-nameservers to
/etc/network/interfacesfile has not helped either.
After each of these experiments failed to enable DNS lookups I restored the original config. I’m not able to install external packages right now such as dnsmasq. Can anyone point me in the right direction? I really am not sure how I got in this mess, but it’s persistent after rebooting as well. I’m not behind a VPN.
