I am trying to install build dependencies for qt with the command sudo apt-get build-dep qtbase5-dev following this guide. The output of apt command listed below:
Reading package lists... Done
Picking 'qtbase-opensource-src' as source package instead of 'qt5-default'
Building dependency tree
builddeps:qtbase-opensource-src : Depends: libfontconfig1-dev but it is not going to be installed
Depends: libfreetype6-dev but it is not going to be installed
Depends: libgtk2.0-dev but it is not going to be installed
Depends: libpng-dev
I have tried apt's autoclean, autoremove, update, upgrade, dist-upgrade and so on. Nothing works for me. Can you please help me.
I use:
Linux ASUS 4.10.0-37-generic #41~16.04.1-Ubuntu SMP Fri Oct 6 22:42:59 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
