I had to uninstall GDB just to upgrade to 17.10, but now I can't get it installed again.
sudo apt install gdb
Reading package lists... Done
Building dependency tree
 gdb : Depends: libpython3.6 (>= 3.6.0~b2) but it is not going to be installed
So I went down the dependency chain:
 libpython3.6 : Depends: libpython3.6-stdlib (= 3.6.3-1ubuntu1) but 3.6.3-1+xenial2 is to be installed
Why is there a reference to Xenial? And why can't it be upgraded?
It seems that GDB requires a specific version, that doesn't match the xenial one. Attempting to remove the package is nigh impossible because of the number of packages which depend on libpython3.6.
Further information:
apt-cache showpkg
Package: libpython3.6
Versions:
3.6.3-1ubuntu1 (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_artful_main_binary-amd64_Packages)
apt-cache showpkg
Package: python3.6
Versions:
3.6.3-1+xenial2 (/var/lib/dpkg/status)
So my guess is that APT doesn't have a handle on where it got the +xenial2 package from.
Robobenklein
  • 1,496
On clean 17.10 installation gdb installs without problems.
You may have PPA.
Please check output of
  • ls -al /etc/apt/sources.list.d/*.list (list PPAs sources.lists),
  • aptitude search '?narrow(?installed, ~Oppa)' (list of packages, installed from PPAs),
  • aptitude search '?narrow(?installed, ~o)' (list of obsolete packages) - see this answer for reference.
Also you can check solution from "How do I resolve unmet dependencies after adding a PPA?".
UPDATE: it seems that you simply have python3.6 from deadsnakes team's PPA:
see http://ppa.launchpad.net/deadsnakes/ppa/ubuntu/pool/main/p/python3.6/ (check it for 3.6.3-1+xenial2 versions).
N0rbert
  • 103,263
The issue here is that the package version 3.6.3-1+xenial2 was considered newer than 3.6.3-1ubuntu1.
The fix was to downgrade the package, even though the actual python version was the same.
This was a weird issue to fix because I hadn't used any PPAs which N0rbert suggested, and the package was considered newer than the main repos one (although it wasn't).
This may have been because I had first installed this system on Xenial, which might have had something to do with why I had that strange version installed. (Potentially a backport with different naming scheme?)
On downgrading packages: How to downgrade a package via apt-get?
Robobenklein
  • 1,496
Try this to fix it :
sudo apt install python
Or
sudo apt install python2
Then :
sudo apt install pip
Type the following commands in your terminal to install gdebi :
sudo add-apt-repository universe
then :
sudo apt-get update
then install gdebi core :
sudo apt-get install gdebi-core
You need to install the gdebi package if you want GDebi GUI, which mean the app, which is easier to use.
Ibster
  • 402
