I'm trying to install Vulkan on Ubuntu 17.10.
So far I've tried:
sudo apt install mesa-vulkan-drivers vulkan-utils
This does not appear to work, since I get the following output from vulkaninfo:
VULKAN INFO
Vulkan API Version: 1.0.42
INFO: [loader] Code 0 : Found manifest file /home/<redacted>/.local/share/vulkan/implicit_layer.d/steamoverlay_i386.json, version "1.0.0"
INFO: [loader] Code 0 : Found manifest file /home/<redacted>/.local/share/vulkan/implicit_layer.d/steamoverlay_x86_64.json, version "1.0.0"
INFO: [loader] Code 0 : Found ICD manifest file /etc/vulkan/icd.d/intel_icd.i686.json, version "1.0.0"
ERROR: [loader] Code 0 : /usr/lib/i386-linux-gnu/libvulkan_intel.so: cannot open shared object file: No such file or directory
INFO: [loader] Code 0 : Found ICD manifest file /etc/vulkan/icd.d/radeon_icd.x86_64.json, version "1.0.0"
INFO: [loader] Code 0 : Found ICD manifest file /etc/vulkan/icd.d/intel_icd.x86_64.json, version "1.0.0"
INFO: [loader] Code 0 : Found ICD manifest file /etc/vulkan/icd.d/radeon_icd.i686.json, version "1.0.0"
ERROR: [loader] Code 0 : /usr/lib/i386-linux-gnu/libvulkan_radeon.so: cannot open shared object file: No such file or directory
INFO: [loader] Code 0 : Found ICD manifest file /usr/share/vulkan/icd.d/radeon_icd.x86_64.json, version "1.0.0"
INFO: [loader] Code 0 : Found ICD manifest file /usr/share/vulkan/icd.d/intel_icd.x86_64.json, version "1.0.0"
Instance Extensions:
Instance Extensions count = 6
VK_KHR_surface : extension revision 25
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
VK_KHR_wayland_surface : extension revision 5
VK_KHR_mir_surface : extension revision 4
VK_EXT_debug_report : extension revision 5
/build/vulkan-WFoCfr/vulkan-1.0.42.0+dfsg1/demos/vulkaninfo.c:1523: failed with VK_ERROR_INITIALIZATION_FAILED
Here's the output from lscpi:
01:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Tobago PRO [Radeon R7 360 / R9 360 OEM] [1002:665f] (rev 81)
Specifically, my graphics card is a Radeon R7 360.
Is there something I need to do to activate the drivers? It feels like I'm missing something super obvious...
