How can I scale recipes in krecipes?
Suppose I have a recipe in krecipes which is for 4 persons. Now want to scale the amount of incredients that it fits for 3 persons (or even 3.5 if you have 3 adults and one child for example).
On their handbook page under Recipe Actions you have two options, scale by yield or scale by factor. It sounds like you want the second one. Look for the Resize recipe button in the edit recipe page. Note that this will change the entire recipe each time you do this. Keep a backup copy of the original in case the scaling back and forth doesn't work out over time.
To request this as a feature, select Help/Report Bug in the menu. Type in your feature request. The KDE help document explaining this in greater detail is here.
To do this now, you need to use one of the many online recipe scaling calculators found through a search. You probably did this already, I'm just including all the options here.
