The upgrade failed, but I was planning to re-install anyways because I kept getting error messages with compiz and unity, with occasional crashes + bugs (see my other posts + some).
I can easily access grub and the recovery menu, as well as a live USB, so I can only use those three paths to access my data.
If it's easier to repair the current installation; then there are two lines in the sequence that fail, but they go by so fast I can't read what they are. I will find out what they are if necessary though.
J.Tho
  • 321
Yes you can, but it would not be wise as you seem to have compiz and unity problems as well and these could be profile- or system-related, so the safest bet is to:
cp --recursive --preserve=timestamps /home/szYourUser /media/backup/szYourUser
reinstall and copy only your documents, videos, music, ... folders back and be done with it.
For important individual applications, you can restore individual hidden config files, but I would definitely not restore the entire /home unless you know exactly where the trouble is coming from and exclude those config files...
Fabby
  • 35,017
