44
I created a swap file in Ubuntu by following this process, but I no longer need it, so I would like to delete it.
However, the blog article doesn't write anything regarding the deletion, so I tried deleting it via sudo rm -rf, but it got the Operation not permitted error.
So far, I tried many answers to how to delete a file with the same error, but nothing worked in my case:
, which include:
  • change the permission of both the swapfile and the root directory / (hmod ugo+w .)
  • change the immutable flag on both the swapfile and / (chattr -i -a .)
  • reboot the system
All of them didn't work. I wonder how I can delete it, but if it is a swap file, how can I delete it?
The result of free -h is:
              total        used        free      shared  buff/cache   available
Mem:           1.7G        101M        405M        1.2M        1.2G        1.4G
Swap:          1.5G        234M        1.3G
muru
  • 207,228
Blaszard
  • 891
The output of free -h indicates that swap is being used - the swap process is still running.
Enter the command
sudo swapoff /path/to/swapfile/to/be/deleted
This will disable the swapfile, and the file can be deleted at that point.
Please note that if you have created an entry in /etc/fstab for the swapfile, you should also delete it (or comment it out by adding # at the beginning of the line).
Charles Green
  • 21,859
Run the following commands to delete the swap file:
sudo swapoff -a -v
sudo rm /swapfile
#back up /etc/fstab:
sudo cp /etc/fstab /etc/fstab.bak
sudo sed -i '/\/swapfile/d' /etc/fstab
khalidh
  • 180
