I have using various versions of Ubuntu over the 5 years on my Samsung NC10 netbook. This is a triple boot system which has Windows XP (the original operating system) Windows 10 (which was an upgrade from Windows 7 ) and Ubuntu. apart from an issue with wireless networking not starting properly a few releases ago which has since been fixed without me doing anything everything has worked as expected so I have never needed to delve into the mysteries of terminal and Linux commands. However the upgrade from 17.04 to 17.10 has not worked as on booting up the system and selecting the Ubuntu option the screen eventually stabilises with about 80% on the left hand side corrupted and the remaining 20% written correctly. I can select the drop down menu for shut down but the pop up menu is obviously displayed in the corrupted bit. So I have to do a hard reset.
Tips please on what to do next.
J.Roe
The same issue happens on Acer Aspire One A110 (ZG5)
  • When system is booting and grub shows up, press "e"
  • Find line with "ro quiet splash" and add nomodeset so it says "ro nomodeset quiet splash".
  • Press CTRL-X to continue booting
Then there are two workarounds:
  1. if you need the new kernel 4.13, you can add "nomodeset" to your kernel options permanently, but this will limit screen resolution to 800x600:
    • $ sudo vi /etc/default/grub
    • Then add "nomodeset" as below:
    • GRUB_CMDLINE_LINUX_DEFAULT="nomodeset quiet splash"
    • $ sudo update-grub
  2. if you don't mind running older kernel 4.10 and want full 1024x600 resolution, try this solution Set "older" kernel as default grub entry to set up kernel 4.10 as default (framebuffer works fine in this version, in 1024x600 and without having to use nomodeset)
Pablo Bianchi
  • 17,371
Fixing this issue on my Samsung N130 using 17.10.1 (artful) was slightly different. The suggested lines in the normal grub weren't there. The fault was in the graphics driver trying to set an invalid resolution, or one that the video card really doesn't like.
To get around it the correct way is to force grub to use "terminal" mode.
  • Edit /etc/defult/grub using your favourite command-line editor (vi, nano, whatever) in recovery mode or through SSH (if enabled).
  • Look for the line #GRUB_TERMINAL=console and remove the #
  • Save and exit your editor
  • Run update-grub2
  • Reboot
Grub should be in the default boot VGA resolution, but Linux should still boot up using the native resolution of your display and work correctly.
Majenko
  • 484
This workaround helps to get working the display normaly:
Suspend the system in the corrupted login screen (luckily the 20% good screen shows the dropup menu to choose) Wake up the system (press power button) and the login screen is showing up normaly
I have just observed the same problem. I was able to boot into the previous kernel (4.10.0-37) successfully. Also, booting into recovery mode in the latest kernel (4.13.0-16) and immediately selecting 'continue' boots successfully into an 800 by 600 screen. Not a solution but at least you can use the netbook.
