Recently I accidentally changed the permission of all file in the root directory to world readable/writable on my ubuntu 16.04. Somehow I managed to solve the majority of the problem but stuck with wifi module. So I thought of upgrade but having the following issue with "sudo apt-get update" commands: error part 1
error part 2
error part 3
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/cache/app-info -a -e /usr/bin/appstreamcli; then appstreamcli refresh > /dev/null; fi'
E: Sub-process returned an error code
Any help is much appreciated!
George Udosen
  • 37,534
Manish Singla
  • 172
There's two links that you should take a look at. The first addresses your update process:
appstreamcli hanging with 100% CPU usage during update
The second addresses changing the root permissions:
What if I accidentally run command "chmod -R" on system directories (/, /etc, ...)
Charles Green
  • 21,859
