I am using this command
sudo apt-get update && wget https://minergate.com/download/deb-cli && mv deb-cli minergate-cli-release.deb && sudo apt-get install -y gdebi && sudo gdebi minergate-cli-release.deb && screen minergate-cli -user someone@any.com --xmr
So first I need force yes; when prompted with "do you want to install software package?" y/n
I need to auto select y
Secondly I need to run this whole command in the background. It takes a long time to install.
Zanna
  • 72,312
Astril
append a "&" to your command ;)
  1. By providing -y option with apt-get you can skip the confirmations while installing.
  2. You can use the screen command to get in to a screen console in which you can perform long time installations so that you can detach and attach the screen as per you want.
    Type apt-get install screen in a terminal to install screen.
Once installed type screen in the terminal to get in to screen.
You can perform the commands in the screen.
Use key combinations CTRL + A + D to detach the screen and CTRL +RX to re-attach the screen if you have only one screen running(In this case only one screen is running)
Rooney
  • 975
