Dont know if this is the right place to ask.
Hi, i have a small problem with my vps. I use windows remote desktop connection to connect to the vps. I login using root and my password, and everything is working as intended, but when i disconnect from the vps/ close windows remote desktop connection and log into it again i cant see any of the applications that i had open when i disconnected, but the applications is still taking resources. I use windows remote desktop connection to connect to the vps. The vps use Ubuntu 14.04 64bit
Thanks for answers
commands i used when i set it up: sudo apt-get update sudo apt-get install ubuntu-desktop sudo apt-get install xrdp sudo apt-get update sudo apt-get install xfce4
Just using the close button from your remote desktop client never close the session on the server, this is a normal behavior. You have to use the logout function from your server windows manager in order to ensure that all applications are properly closed.
ob2
  • 3,653
