I have a lot of photos that need to be renamed.
I need all the square brackets to be removed. To do so, I found this & this.
Using sed command as in those pages, the space before and after the brackets is still there. In my case, I want the text inside, space before & after, and the brackets itself to be removed.
To remove [first]  &  [last] brackets, how can I do that with a sed command?
Zanna
  • 72,312
Hidayats
  • 195
You shouldn't use sed to rename files, but you can use the Perl program rename, for example:
$ rename -n 's/\[[^]]+\] ([^[]+) \[[^]]+\]/$1/' *
rename([Beach] Music Fest_58 [August].jpg, Music Fest_58.jpg)
rename([Mountain] Summer Camp_165 [May].jpg, Summer Camp_165.jpg)
rename([Wedding] Happy Day_001 [February].jpg, Happy Day_001.jpg)
Remove -n after testing to actually rename the files.
Notes
  • s/old/new replace old with new
  • \[ literal [
  • [^[]+ some characters that are not [
  • (stuff) save stuff for later to reference as $1, $2 etc
This only works if your filenames are consistent. muru's answer is much more portable.
Zanna
  • 72,312
sed is the wrong tool. It doesn't rename files. While you can pair it with something that can, it's simpler to use rename from Perl:
rename -n 's/\[.*?\]//g' *
With -n, rename will show what changes will be made. Run without -n to actually rename the files. rename is Perl, and in Perl, .*? is not a greedy match like .*, so you don't need to use tricks like [^]]*.
To remove surrounding whitespace as well:
rename -n 's/\s*\[.*?\]\s*//g' *
muru
  • 207,228
