I'm running Ubuntu 16.04.3 LTS. The installation was done by a computer shop (I had a faulty hard drive, which they replaced). I'd like to see if they set up my partitions as I requested. How can I view the partition sizes and mount points?
You can use GParted(GNOME Partition Editor). To install it in Ubuntu, run the following commands(one-by-one) :-
sudo apt-get update
sudo apt-get install gparted
After installation, you can use GParted Partition Manger to view partition sizes and mount points.
try df. Sometimes is enough. By default you get something like
Filesystem     1K-blocks      Used Available Use% Mounted on
/dev/sda3       65389132  23268884  38775608  38% /
tmpfs            2004540     19004   1985536   1% /tmp
/dev/sda5      169672296 142616624  18430080  89% /home
/dev/sda1       64147300  50588732  10293340  84% /backups
several options available.
You can use the following command lines, that together will give you a good overview of the partitions (location, sizes, free space and mount points),
df -h
sudo parted -ls
sudo lsblk -f
sudo lsblk -m
If your terminal window is wide enough (for example 130 characters), you can combine the lsblk commands to
sudo lsblk -fm
sudodus
  • 47,684
