12
In Ubuntu 17.04 I could use wmctrl to switch to a gnome-terminal window with given window ID:
wmctrl -ia $gnome_term_winid
The window ID of a given gnome-terminal could also be displayed from the terminal by typing:
echo $WINDOWID
After upgrading to Ubuntu 17.10, this is no longer the case. First, echo $WINDOWID gives nothing, and also wmctrl -lx does not show any gnome-terminal windows.
wmctrl doesn't work properly in a Wayland session as controlling windows is against Wayland's security policy.
wmctrl may work with the application windows running under the XWayland compatibility layer (for example Firefox). But gnome-terminal is an official GNOME app which doesn't run under XWayland so it fails.
You may try to switch to an Xorg session as a workaround.
pomsky
  • 70,557
