I'm trying to get this ASUS USB-AC56 adapter installed on Ubuntu 17.10. I have upgraded from Ubuntu 17.04. The Driver bundle from Github as well as proprietary drivers that came with the device are not working. Errors encountered during make are appended below.
cc1: some warnings being treated as errors
scripts/Makefile.build:302: recipe for target '/home/unispirited/DR_USB_AC56_4314_Linux/RTL8812AU_linux_v4.3.13_14061.20150505/driver/rtl8812AU_linux_v4.3.13_14061.20150505/core/rtw_cmd.o' failed
make[2]: *** [/home/unispirited/DR_USB_AC56_4314_Linux/RTL8812AU_linux_v4.3.13_14061.20150505/driver/rtl8812AU_linux_v4.3.13_14061.20150505/core/rtw_cmd.o] Error 1
Makefile:1546: recipe for target '_module_/home/unispirited/DR_USB_AC56_4314_Linux/RTL8812AU_linux_v4.3.13_14061.20150505/driver/rtl8812AU_linux_v4.3.13_14061.20150505' failed
make[1]: *** [_module_/home/unispirited/DR_USB_AC56_4314_Linux/RTL8812AU_linux_v4.3.13_14061.20150505/driver/rtl8812AU_linux_v4.3.13_14061.20150505] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.13.0-16-generic'
Makefile:1622: recipe for target 'modules' failed
make: *** [modules] Error 2
Compile make driver error: 2
Please check error Mesg
On the Github driver make and sudo make install works but sudo modprobe 8812au gives
modprobe: ERROR: could not insert '8812au': Exec format error
please help in getting the Wifi Adapter to work.
Thomas
  • 6,433
With a working internet connection by ethernet, tether or whatever means possible, I suggest that you do:
sudo apt update
sudo apt install rtl8812au-dkms
In the case of the driver you attempted to compile, if the process fails at 'make,' then all further steps will fail as well.
EDIT: Let’s try a different driver package. First, remove the package that won’t compile:
sudo apt purge rtl8812au-dkms
Next, do:
sudo apt update
sudo apt install git
git clone https://github.com/gnab/rtl8812au.git
sudo cp -r rtl8812au  /usr/src/rtl8812au-4.2.2
sudo dkms add -m rtl8812au -v 4.2.2
sudo dkms build -m rtl8812au -v 4.2.2
sudo dkms install -m rtl8812au -v 4.2.2
Reboot and tell us if the wireless is working.
chili555
  • 61,330
