I am installing some open source software by compiling its source code -- on Ubuntu 16.04 -- by following the instructions in its 'readme' file. At certain point (point 3b in the link) the guideline requires me to run a .csh file located in a certain directory in order to generate executables. When I execute the required csh script from the terminal in the required directory by typing ./compile_all.csh, or run csh to start an interactive shell, I am met with following line on terminal:
MANPATH: undefined variable.
Can anyone guide me how can I fix this error?
The following is the result of the manpath command when executed from an Ubuntu terminal:
~$ manpath
/home/atrcheema/share/man:/usr/local/man:/usr/local/share/man:/usr/share/man
The ~./cshrc file contained just one line as seen by execution of following command:
:/home$ vim ~/.cshrc
setenv MANPATH ${MANPATH}:${HOME}/share/man
The first few lines of compile_all.csh are as follows:
#!/bin/csh
####### section added by York Prado 10/2009
if( ! (-e /usr/bin/f77 || -e /bin/f77 || -e /usr/local/bin/f77) ) then
echo "f77 command is not found"
echo "Please make sure you have the fortran 77 compiler installed"
exit 1
endif
# section below moved to compile_hspf_libs.csh
#cd hspf/lib3.2/src/util
#make clean
#make
#make install
#cd ../
#cd wdm/
#make clean
#make
#make install
#cd ../
#cd adwdm/
#make clean
##make
#make install
#echo "Compiled all the lib3.2 files needed to compile the CBWM"
#cd ../../../../
######### end York Prado section
cd lib/dsn/
f77 -c dsn_utils.f
cd ../util
rm ../util_lib.a
./compile
cd ../get
rm ../get_lib.a
./compile
cd ../tty/
gcc -c -o ../ttyux.o ttyux.c
