I have just installed Awesome WM and I have no options to change the screen brightness, and also its shortcut doesn't working. Any one can help?
In the globalkeys = awful.util.table.join( section of ~/.config/awesome/rc.lua:
-- Brightness
awful.key({ }, "XF86MonBrightnessDown", function ()
awful.util.spawn("xbacklight -dec 15") end),
awful.key({ }, "XF86MonBrightnessUp", function ()
awful.util.spawn("xbacklight -inc 15") end),
- 105
- 211
- 2
- 3
1) Install xbacklight:
sudo apt-get install xbacklight
2) Test it in console:
xbacklight -inc 10
xbacklight -dec 10
3) Add hotkeys to your awesome config ~/.config/awesome/rc.lua
Insert inside [globalkeys = awful.util.table.join] section the following text:
I use a keyboard without XF86MonBrightness* that's why I added bindings to Mod+o, Mod+p:
awful.key({ modkey, }, "p", function ()
awful.key({ modkey, }, "o", function ()
Hope this helps )
- 374
I autostart xfce4-power-manager, which will let you adjust the brightness using the brightness keys, in addition to general power management, such as suspend/resume, battery notifications, etc.
- 7,582
- 4
- 43
- 74
One way is to load "gnome-power-manager" inside awesome, or at awesome startup: https://wiki.archlinux.org/index.php/Awesome#Transitioning_away_from_Gnome3 Hope this helps
Another option is to run awesome inside gnome, then you can just rely on the gnome controls (working fine) and networking etc is working too http://awesome.naquadah.org/wiki/Quickly_Setting_up_Awesome_with_Gnome
- 101
To make an app autostart when you login in Awesome WM: Right click on Desktop go to awesome > edit config. append the following line at the end:
-- Autorun programs in Awesome WM
autorun = true
autorunApps =
"xfce4-power-manager",
if autorun then
for app = 1, #autorunApps do
awful.util.spawn(autorunApps[app])
end
end
Replace "xfce4-power-manager" with your power manager.
- 11
