24
Running Unity on fresh install of 14.04. I installed Unity Tweak Tool through the Software Center, and on initial launch it said:
The following schema is missing
com.canonical.notify.osd
In order to work properly, Unity Tweak Tool recommends you install the necessary packages.
So in the terminal I used
sudo apt-get install notify-osd
Then, when I tried to open Unity Tweak Tool again, I got the same message but instead of com.canonical.notify.osd, it's saying com.canonical.desktop.interface is missing. How do I get this to run?
pomsky
  • 70,557
Tony
  • 445
I had the same issue, and I used the above solutions. Both were required to achieve a solution.
sudo apt-get install overlay-scrollbar
Now it works perfectly.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Solomon
  • 526
For what it's worth, I had this issue on 18.04 and it was solved only by running
sudo apt install notify-osd
I didn't need to install overlay-scrollbar.
leafmeal
  • 141
Used
Works now.
Tony
  • 445
