I've got two Ubuntu boxes running who have both developed the same problem.
They keep throwing up error messages about how I'm out of space.
Error: BrokenCount > 0
Tried to run sudo apt-get -f install:
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-83-generic_4.4.0-83.106_amd64.deb (--unpack):
cannot copy extracted data for './boot/System.map-4.4.0-83-generic' to '/boot/System.map-4.4.0-83-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-83-generic /boot/vmlinuz-4.4.0-83-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-83-generic /boot/vmlinuz-4.4.0-83-generic
Preparing to unpack .../linux-image-4.4.0-93-generic_4.4.0-93.116_amd64.deb ...
Done.
Unpacking linux-image-4.4.0-93-generic (4.4.0-93.116) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-93-generic_4.4.0-93.116_amd64.deb (--unpack):
cannot copy extracted data for './boot/vmlinuz-4.4.0-93-generic' to '/boot/vmlinuz-4.4.0-93-generic.dpkg-new': failed to write (No space left on device)
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-93-generic /boot/vmlinuz-4.4.0-93-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-93-generic /boot/vmlinuz-4.4.0-93-generic
Preparing to unpack .../linux-image-4.4.0-96-generic_4.4.0-96.119_amd64.deb ...
Done.
Unpacking linux-image-4.4.0-96-generic (4.4.0-96.119) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-96-generic_4.4.0-96.119_amd64.deb (--unpack):
cannot copy extracted data for './boot/System.map-4.4.0-96-generic' to '/boot/System.map-4.4.0-96-generic.dpkg-new': failed to write (No space left on device)
No apport report written because MaxReports is reached already
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-96-generic /boot/vmlinuz-4.4.0-96-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-96-generic /boot/vmlinuz-4.4.0-96-generic
/var/cache/apt/archives/linux-image-4.4.0-97-generic_4.4.0-97.120_amd64.deb
Deleted a load of files, still wouldn't fix my dependencies. How'd my pipe break and what should I do to fix this?
df:
Filesystem 1K-blocks Used Available Use% Mounted on
udev 3529056 0 3529056 0% /dev
tmpfs 710068 17808 692260 3% /run
/dev/mapper/ubuntu--vg-root 953106324 11889680 892778580 2% /
tmpfs 3550320 800 3549520 1% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 3550320 0 3550320 0% /sys/fs/cgroup
/dev/sda2 483946 474540 0 100% /boot
/dev/sda1 523248 3664 519584 1% /boot/efi
tmpfs 710068 84 709984 1% /run/user/1000
/home/frank/.Private 953106324 11889680 892778580 2% /home/frank
Any help would be appreciated, thanks!
