I upgraded to texlive 2017 but had some issues with it and therefore wanted to go back to the 2015 version. I removed it with sudo apt-get purge --auto-remove texlive* but it did not seem to remove everything. When I try sudo apt-get install texliveI get the following error:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
libosgi-compendium-java : Depends: libgeronimo-jpa-2.0-spec-java but it is not going to be installed
texlive : Depends: texlive-latex-recommended (>= 2015) but it is not going to be installed
Depends: texlive-latex-base (>= 2015) but it is not going to be installed
Depends: texlive-fonts-recommended (>= 2015) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I then tried to follow the steps explained in this post but it did not help in this situation. Any ideas?
Thanks in advance!
