martin@martin:~$ sudo apt-get install netbeans
Reading package lists... Done
Building dependency tree
netbeans : Depends: libnb-apisupport3-java (= 8.1+dfsg3-1) but it is not going to be installed
Depends: libnb-ide14-java (= 8.1+dfsg3-1) but it is not going to be installed
Depends: libnb-java5-java (= 8.1+dfsg3-1) but it is not going to be installed
When running sudo apt-get install netbeans I get error when I try to run
martin@martin:~$ sudo apt-get install oracle-java8-installer
oracle-java8-installer is already the newest version (8u131-1~webupd8~2).
The following packages were automatically installed and are no longer required:
libavcodec57 libavfilter6 libavformat57 libavresample3 libavutil55 libchromaprint0 libllvm3.8 libpostproc54 librubberband2v5 libswresample2
libswscale4 libtidy5
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
How to fix this error in installing netbeans in ubuntu
