So I was having some problems with my network manager and I tried to reinstall it as it wouldn't work at all.
Fast forward a few packages later and now the network manager and network work but I have no icon, on the top right side, with the networks. I have this error icon with the erorr message :
"Error: BrokenCount>0".
Following the instructions provided doesn't solve the problem as I still get the error as bellow.
The Ubuntu Software installer doesn't work as well. When I try to install/update something it just loads a little and then stops as if I canceled.
If someone could solve this one I would be thankful.
sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Correcting dependencies... failed.
aptitude:i386 : Depends: libapt-pkg4.12:i386 (>= 0.8.16~exp12ubuntu6) but it is not installable
Depends: libboost-iostreams1.46.1:i386 (>= 1.46.1-1) but it is not installable
Depends: libc6:i386 (>= 2.4) but it is not installed
Depends: libcwidget3:i386 but it is not installable
Depends: libept1.4.12:i386 but it is not installable
Depends: libgcc1:i386 (>= 1:4.1.1) but it is not installed
Depends: libncursesw5:i386 (>= 5.6+20070908) but it is not installed
Depends: libsigc++-2.0-0c2a:i386 (>= 2.0.2) but it is not installable
Depends: libsqlite3-0:i386 (>= 3.6.5) but it is not installed
Depends: libstdc++6:i386 (>= 4.6) but it is not installed
Depends: libtinfo5:i386 but it is not installed
Depends: libxapian22:i386 but it is not installable
Recommends: apt-xapian-index:i386 but it is not installable
Recommends: libparse-debianchangelog-perl:i386 but it is not installable
libnl-genl-3-200 : Depends: libnl-3-200 (= 3.2.27-1ubuntu0.16.04.1) but 3.2.29-0ubuntu2.1 is installed
libnspr4:i386 : Depends: libc6:i386 (>= 2.17) but it is not installed
ppa-purge : Depends: aptitude
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies`
