Even after doing the change in the Settings > Brightness & Lock, by increasing the value for Turn screen off when inactive for to 5 minutes, it didn't work. I did try the other options there as well.
I've already gone through the steps in this SO.
Is this a current bug, or is there any hack to prevent this? Any help would be appreciated.
dadexix86
  • 6,776
Terminal CLI method
To prevent screen from turning off you need two settings, one under battery power the other when plugged into wall outlet (A/C).
For battery timeout:
gsettings set org.gnome.settings-daemon.plugins.power sleep-inactive-battery-timeout <time_in_seconds>
For AC timeout:
gsettings set org.gnome.settings-daemon.plugins.power sleep-inactive-ac-timeout <time_in_seconds>
So for both Battery and A/C set the time to 0 (never).
For Login screen:
gsettings set org.gnome.desktop.screensaver idle-activation-enabled false
Disable dimming screen when idle:
In Unix & Linux someone complained when on battery screen dims every 20 seconds and wants to turn that feature off:
gsettings set org.gnome.settings-daemon.plugins.power idle-dim false
