I've written a bash script to install some packages on the first boot of my Ubuntu 16.04 VPS. The VPS platform that I'm using runs it during the server commissioning process. When it runs I'm getting this sort of error:
Reading package lists...
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
So my question is: How do I sleep until it's okay go go ahead with the install?
I've done quite a bit of Googling to find a solid answer to this (I'm new to bash scripting), and have come across several proposed solutions, but there's lots of noise. Some answers are specific to certain provisioning systems, and other approaches seem a bit hacky.
My solution at the moment is just a sleep 30 at the top of my script which is definitely not a robust solution.
I tried putting together something like this but it doesn't seem to work:
while true
do
sudo lsof /var/lib/apt/lists/lock &> /dev/null
[ $? = 0 ] && break
sleep 1
done
On my personal machine it sleeps forever because of an error (WARNING: can't stat() fuse.gvfsd-fuse...), and on the VPS, it doesn't seem to sleep at all.
Any ideas why that doesn't work, or ideas for a better approach?
By the way, if you're interested, the script I'm trying to run is simply:
#!/bin/sh
curl -sL https://deb.nodesource.com/setup_8.x | bash -
apt-get install -y nodejs
And the full output can be seen in this pastebin.
