I am running ubuntu 17.04 on an asus x205ta, and through much struggle and research finally got the wifi working. I was so happy and decided to restart the pc just to make sure and come to my knowledge it does not work, unless I run these commands in the terminal once again:
sudo modprobe brcmfmac
I am using a guide I found on another post here: How to install (L)Ubuntu 16.04 on the ASUS X205TA (F205TA)
I think the problem could be that maybe the /etc/rc.local file that is suppose to be an executable is not becoming one or otherwise I have no clue. I am brand new to linux and this is my first time messing with it.
UPDATE: It is actually only the sudo modprobe brcmfmac command I have to run that I know of now. Im not sure if the others still have to be ran or not. It is also worth mentioning that in the guide the wifi should work before these steps are taken and mine does not until these commands are issued.
UPDATE2: The rc.local file is executable so that is not the problem.
Running command grep brcmfmac /etc/modprobe.d* returns grep: /etc/modprobe.d: Is a directory
Running command cat /etc/modprobe.d/* | grep brcmfmac returns blacklist brcmfmac
Running command sudo grep brcmfmac /etc/modprobe.d/* returns /etc/modprobe.d/blacklist-custom.conf:blacklist brcmfmac
Taylor Austin
  • 177
Your card is blacklisted
You have to run sudo modprobe brcmfmac because it is blacklisted. You can tell this when you ran the command:
$ sudo grep brcmfmac /etc/modprobe.d/*
In order to "whitelist" your card you need to use sudo powers to edit etc/modprobe.d/blacklist-custom.conf. Then:
  • Find the containing blacklist brcmfmac
  • Insert a # in front of it.
  • Save the file
Now when you reboot you shouldn't have to type sudo modprobe brcmfmac anymore.
Thanks to Jeremy31 for recommending shorter version of my original answer. If yuou like this shorter answer please click on his name link find another answer of his you find helpful and upvote it.
Please note there is a reason your card was blacklisted in the first place and if you have additional problems you might have to download source for a different driver and compile it using DKMS.
You need to do the following fixes:
Wifi driver install.
Open up the terminal and type in the following commands (or you could copy and paste them)
cd /tmp
wget https://android.googlesource.com/platform/hardware/broadcom/wlan/+archive/master/bcmdhd/firmware/bcm43341.tar.gz
tar xf bcm43341.tar.gz
sudo mkdir -p /lib/firmware/brcm/
sudo cp fw_bcm43341.bin /lib/firmware/brcm/brcmfmac43340-sdio.bin
sudo mount -t efivarfs efivarfs /sys/firmware/efi/efivars
sudo cp /sys/firmware/efi/efivars/nvram-74b00bd9-805a-4d61-b51f-43268123d113 /lib/firmware/brcm/brcmfmac43340-sdio.txt
reboot
Wifi stability fix.
Open the text editor and type the following text into it
blacklist btsdio
Save the file as "fix-wifi.conf" on the desktop
  • sudo thunar
  • Move the "fix-wifi.conf" file from the desktop to the directory "/etc/modprobe.d"
  • Close the file manager window
Type into the terminal
sudo update-initramfs -u -k all
sudo reboot
