Hello there. I am new in Ubuntu and I just installed python 3.6 and was happy about it but suddenly i noticed that I cant open terminal anymore. I used the shortcut before, but now it just doesn't work! I tried run Terminal from application but it just shows icon in task bar and then just goes away, nothing happens. But the weirdest thing is I can open it from folder and it is working just fine.
I thought it was caused by some my personal setting but in ~/.gconf I don't have any other folder so i can't delete some Terminal settings.
Hope someone knows what is going on.
I met the same problem. I solved it by
sudo nano /usr/bin/gnome-terminal
and change #!/usr/bin/python3 to #!/usr/bin/python3.6. I changed to 3.7 at first as I installed it, but it didn't work. It only works after I changed to 3.6. Refer to this
RaynCC
You might have a compatible issue for the gnome-terminal Python script in your Ubuntu versus the newly installed python 3.6. Please refer to this.
