I always use a proxy to connect to the internet in Windows as well as in previous versions of Ubuntu, but in Ubuntu 11.10 it seems that the proxy settings I set in the GUI are not being applied system-wide.
I can access the internet in Firefox with its own proxy settings. I can access internet in the terminal (i.e. I am able to use apt-get for some small programs). But in Ubuntu software centre or update manager it is not working.
Prakash
I was having this problem when I first installed Ubuntu 11.10. I don't know which of the following steps solved it, but this is what I did:
  • Open a terminal
  • Run export HTTP_PROXY=http://<myproxy>:<port> to set up the proxy server for that terminal session
  • Run sudo apt-get update
  • At this point, the update manager popped up and asked if I'd like to install c. 300 updates, which I did
  • Restart
  • Install dconf with sudo apt-get install dconf-tools
    or Using Software Center Install via the software center
  • Run dconf-editor, select system > proxy > http and click enable (as per the tutorial in teleblog's answer)
And now it all seems to work :)
This tutorial worked for me:
First. You must install dconf-tools in the following ways:
Second. Run dconf-tool the way:
dconf-editor
Third. In the Configuration Editor menu select System>> proxy
Goto “system >> proxy” change “mode” to manual and select “use-same-proxy“.
Goto “system >> proxy >> http” give your proxy information there and select “enable” option.
Goto “system >> proxy >> https” give your proxy information there, do the same things on ftp part.
Make sure socks have “0” (zero) on “port” and nothing on “Host” field.
http://loewyi.com/info/proxy-problem-google-chrome-ubuntu-11-10/
telebog
  • 155
You should export proxy by root user
Just type in a terminal:
sudo -s
export http_proxy=http://yourdomain.com:port
apt-get update
Anwar
  • 77,855
Ucha
Go to system setting>network. There you can manually adjust your proxy settings.
Harridi
