I run the command
usermod -a -G dialout amashreghi
but I get amashreghi doesn't exists, however, when I try to add the user using adduser
adduser amashreghi
It says that amashreghi already exists. What's going on?!
I run the command
adduser amashreghi
To edit /etc/group directly use vigr
From man vigr
NAME
vipw, vigr - edit the password, group, shadow-password or shadow-group file
SYNOPSIS
vipw [options]
vigr [options]
DESCRIPTION
The vipw and vigr commands edits the files /etc/passwd and /etc/group, respectively. With the -s flag,
they will edit the shadow versions of those files, /etc/shadow and /etc/gshadow, respectively. The
programs will set the appropriate locks to prevent file corruption. When looking for an editor, the
programs will first try the environment variable $VISUAL, then the environment variable $EDITOR, and
finally the default editor, vi(1).
Hence, you can edit the /etc/group file with
sudo vigr
The format of group entries can be found in man.
From man group:
NAME
group - user group file
DESCRIPTION
The /etc/group file is a text file that defines the groups on the system. There is one entry per line,
with the following format:
group_name:password:GID:user_list
The fields are as follows:
group_name the name of the group.
password the (encrypted) group password. If this field is empty, no password is needed.
GID the numeric group ID.
user_list a list of the usernames that are members of this group, separated by commas.
FILES
/etc/group
Give this a try. (I'm assuming that you're ready to delete everything associated with this user and start over, don't run these if you're not.)
userdel -r amashreghi
grep amashreghi /etc/passwd
If that second command returns anything, run:
sudo -H gedit /etc/passwd
Remove the line that begins with amashreghi, and save the file. Try adding the user again now.
Just do this:
sudo vim /etc/group
and add your name to the desired group, like:
somegroup:x:25:yourusername
