I installed Packet Tracer 7.1 using command lines. It installed fine but when I type packettracer it just says
starting packettracer 7.1
but doesn't work. I tried every solution I found on the internet but they didn't work.
I was able to run Cisco Packet Tracer 7.1 on Ubuntu 16.04 by doing the following:
1-Cisco Packet Tracer 7.1 requires an older version of a package not present on Ubuntu 16.04 so you need to get it by typing
wget http://security.ubuntu.com/ubuntu/pool/main/i/icu/libicu52_52.1-3ubuntu0.7_amd64.deb
2- To install the package you just downloaded type
sudo dpkg -i libicu52_52.1-3ubuntu0.7_amd64.deb
3- Verify proper installation using this commands
sudo updatedb; locate libicui18n
Check for the following packages to be installed:
/usr/lib/x86_64-linux-gnu/libicui18n.so.52
/usr/lib/x86_64-linux-gnu/libicui18n.so.52.1
Those are the packages needed by Cisco Packet Tracer to work properly.
Now you can type packettracer on terminal and the program should start.
Navigate to the directory where PacketTracer is installed (this is the default):
cd /opt/pt/bin
then run PacketTracer7
./PacketTracer7
Now, if it shows a list of "libqt5xxx" missing libraries, please install them all.
sudo apt install libqt5xxx*
Remember, just write everything that is behind the first "."(dot) and to put the * in the end of the name of the package.
In my case, it was a package named "libQt5Script.so.5", so I did this:
sudo apt-get install libqt5script*
After that, running PacketTracer7
./PacketTracer7
should now work.
If you check out the libraries required by using this command:
cd /opt/pt/bin
ldd Packettracer7
you'll see all the libraries inclunding the missing ones
So to solve this problem just copy the library missing like :
sudo cp /opt/pt/lib/libname /usr/lib/x86_64-linux-gnu
And ta da!!!
Problem solved
i fixed this by
wget http://ftp.br.debian.org/debian/pool/main/i/icu/libicu52_52.1-8+deb8u6_amd64.deb
then this command line
sudo dpkg -i libicu52_52.1-8+deb8u6_amd64.deb
and finally
packettracer
Open terminal type packettracer, make sure you use two t's, packettracer not packetracer, not case sensitive, do not need to change directory, I am running version 7.1.1 on ubuntu 14.04, no need to type packettracer7 or packettracer7.1.1 just packettracer.
My Packettracer program in /opt/pt where it is installed is named packettracer.
There is a known issue between packet tracer 7.1 and Ubuntu 16.04 which blocks packet tracer from starting. Packet tracer needs a library libicui18n.so.52 which has been updated with libicui18n.so.55 in Ubuntu 16.04. To solve this issue, we have to download and install the older version of this library. Older version of this library is available in a Debian package at :-
http://security.ubuntu.com/ubuntu/pool/main/i/icu/libicu52_52.1-3ubuntu0.7_amd64.deb.
Run following commands to download and install this package
sudo dpkg –i libicu52_52.1-3ubuntu0.7_amd64.deb
sudo updatedb
Once package is installed, run following command to update the library path
LD_LIBRARY_PATH=/opt/pt/lib /opt/pt/bin/PacketTracer7
