I have a problem installing winehq-staging, which I'll be using to play some little games.
- When I run
sudo apt-get install --install-recommends winehq-stagingit tells me I need "wine-staging". When I try to install "wine-staging" it tells me to install something else, and this continues infinitely. - When I try
aptitudeit lists all the packages I need but tells me none of them will be installed.
I have already done the following:
- Updated, upgraded and dist-upgraded my packages.
- Manually purged all wine packages and configurations.
- Activated multiarch with i386.
The output of sudo apt-get install wine-staging is the following:
$ LC_ALL=C sudo apt-get install wine-staging
Reading package lists... Done
Building dependency tree
wine-staging : Depends: wine-staging-i386 (= 2.18.0~xenial)
sudo apt-get update output:
pop@201600000:~$ LC_ALL=C sudo apt-get update
Ign:1 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial InRelease
Ign:2 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial Release
Ign:3 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/main amd64 Packages
Ign:4 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/main i386 Packages
Ign:5 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/main all Packages
Ign:6 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/main Translation-en
Ign:7 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/main Translation-fr
Ign:8 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/main amd64 DEP-11 Metadata
Ign:9 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/main DEP-11 64x64 Icons
Ign:10 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/restricted amd64 Packages
Ign:11 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/restricted i386 Packages
Ign:12 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/restricted all Packages
Ign:13 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/restricted Translation-en
Ign:14 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/restricted Translation-fr
Ign:15 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/restricted amd64 DEP-11 Metadata
Ign:16 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/restricted DEP-11 64x64 Icons
Err:3 cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial/main amd64 Packages
Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs
Hit:17 http://archive.canonical.com/ubuntu xenial InRelease
Hit:18 http://archive.ubuntu.com/ubuntu xenial InRelease
Get:19 http://qgis.org/debian xenial InRelease [3344 B]
Hit:20 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu xenial InRelease
Ign:21 http://dl.google.com/linux/earth/deb stable InRelease
Get:22 http://dl.google.com/linux/earth/deb stable Release [2136 B]
Ign:23 http://www-fourier.ujf-grenoble.fr/~parisse/debian testing InRelease
Hit:24 http://archive.ubuntu.com/ubuntu xenial-updates InRelease
Ign:19 http://qgis.org/debian xenial InRelease
Ign:26 http://www-fourier.ujf-grenoble.fr/~parisse/debian stable InRelease
Hit:27 http://archive.ubuntu.com/ubuntu xenial-security InRelease
Hit:28 http://ppa.launchpad.net/kranich/cinnamon/ubuntu xenial InRelease
Ign:29 http://www-fourier.ujf-grenoble.fr/~parisse/debian testing Release
Hit:30 http://www-fourier.ujf-grenoble.fr/~parisse/debian stable Release
Hit:32 https://dl.winehq.org/wine-builds/ubuntu xenial InRelease
Ign:33 http://www-fourier.ujf-grenoble.fr/~parisse/debian testing/main amd64 Packages.diff/Index
Hit:34 http://ppa.launchpad.net/mixxx/mixxx/ubuntu xenial InRelease
Ign:35 http://www-fourier.ujf-grenoble.fr/~parisse/debian testing/main i386 Packages.diff/Index
Ign:36 http://www-fourier.ujf-grenoble.fr/~parisse/debian testing/main all Packages
Ign:37 http://www-fourier.ujf-grenoble.fr/~parisse/debian testing/main Translation-en
Ign:38 http://www-fourier.ujf-grenoble.fr/~parisse/debian testing/main Translation-fr
Ign:39 http://www-fourier.ujf-grenoble.fr/~parisse/debian testing/main amd64 DEP-11 Metadata
Ign:40 http://www-fourier.ujf-grenoble.fr/~parisse/debian testing/main DEP-11 64x64 Icons
Ign:41 http://www-fourier.ujf-grenoble.fr/~parisse/debian testing/main amd64 Packages
Ign:42 http://www-fourier.ujf-grenoble.fr/~parisse/debian testing/main i386 Packages
Hit:41 http://www-fourier.ujf-grenoble.fr/~parisse/debian testing/main amd64 Packages
Hit:42 http://www-fourier.ujf-grenoble.fr/~parisse/debian testing/main i386 Packages
Fetched 5480 B in 18s (295 B/s)
W: The repository 'cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: GPG error: http://qgis.org/debian xenial InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY CAEB3DC3BDF7FB45
W: The repository 'http://qgis.org/debian xenial InRelease' is not signed.
W: The repository 'http://www-fourier.ujf-grenoble.fr/~parisse/debian testing Release' does not have a Release file.
E: Failed to fetch cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719)/dists/xenial/main/binary-amd64/Packages Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs
E: Some index files failed to download. They have been ignored, or old ones used instead.
