I have one 4K monitor (3840 x 2160) and two QHD monitors (2560 x 1440) and I want to have them side by side. This is currently not possible though, since the horizontal virtual resolution required for this is 8960 pixels (3840+2560+2560) but the maximum (horizontal) virtual resolution set by the X server is 8192 pixels. Is there any way to increase the maximum virtual resolution past 8192x8192 pixels?
What I have tried up to now:
- I do not have a xorg.conffile - I tried manually creating one myself including the"Display"sub-section and setting a different"Virtual"value in there, rebooted, nothing changed.
- Tried various xrandrcommand variations with the--fband/or--panningparameters set to the desired maximum (8960x2160+0+0), again to no avail. (output:xrandr: screen cannot be larger than 8192x8192 (desired size 8960x2160))
I did read a claim somewhere (EDIT: here) that Intel's graphics processors do not support greater virtual screen resolutions than 8192x8192 pixels (my system is using a Core i7-6700HQ CPU with the Intel HD Graphics 530 graphics processor), but I unfortunately have been unable to confirm this information - hopefully this is not the case.
EDIT: It is indeed probably not the case:
#: glxinfo -l | grep GL_MAX_TEXTURE_SIZE
GL_MAX_TEXTURE_SIZE = 16384
My xrandr output (I currently have the third monitor positioned bottom-right, hence the 8192x3600 virtual screen resolution):
Screen 0: minimum 320 x 200, current 8192 x 3600, maximum 8192 x 8192
eDP-1 connected primary 3840x2160+2560+0 (normal left inverted right x axis y axis) 346mm x 194mm
3840x2160     60.00*+
2048x1536     60.00
1920x1440     60.00
1856x1392     60.01
1792x1344     60.01
1600x1200     60.00
1400x1050     59.98
1280x1024     60.02
1280x960      60.00
1024x768      60.04    60.00
960x720       60.00
928x696       60.05
896x672       60.01
800x600       60.00    60.32    56.25
700x525       59.98
640x512       60.02
640x480       60.00    59.94
512x384       60.00
400x300       60.32    56.34
320x240       60.05
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 connected 2560x1440+4519+2160 (normal left inverted right x axis y axis) 527mm x 296mm
2560x1440     59.95*+
2048x1152     59.90
1920x1200     59.95
1920x1080     60.00    50.00    59.94    24.00    23.98
1920x1080i    60.00    50.00    59.94
1600x1200     60.00
1680x1050     59.88
1280x1024     75.02    60.02
1280x800      59.91
1152x864      75.00
1280x720      60.00    50.00    59.94
1024x768      75.03    60.00
800x600       75.00    60.32
720x576       50.00
720x576i      50.00
720x480       60.00    59.94
720x480i      60.00    59.94
640x480       75.00    60.00    59.94
720x400       70.08
DP-2 connected 2560x1440+0+285 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440     59.95*+
1280x720      59.86
HDMI-2 disconnected (normal left inverted right x axis y axis)
