i tried to install again Ubuntu in the Windows host OS via the VB after i realized that Ubuntu was not accessible any more. While trying to create a new machine for Ubuntu and mounting as virtual drive the existing .VDI file ( so that hopefully i can reach to the data saved in the previuos Ubuntu virtual machine ) i have to make a choise of Installation type: should i choose ''Erase disk and install Ubuntu'' as i did initially when i installed the former Ubuntu, or one of the other choises, if so which one ?
''Erase'' might eventually mean to erase the existing .VDI file of the former Ubuntu machine, which i precisely want to recover ! So which one of the four Installation types should i select ?
Thanks for any help.
user249018
  • 101
To distil Ben Hiller's link:
Don't install at all to the disk you want to recover.
  • Create a new VM with a lightweight Ubuntu (eg. lubuntu)
  • Create a new VDI for that VM
  • Install to the new VDI
  • Through the Storage tab of your new VM's settings add(+) a new harddrive
  • select 'use existing disk'
  • navigate to your difficult VDI and select it
  • In your new VM, Ctl-Alt T to open a terminal and issue
    $ sudo mkdir /mnt/difficultdrive
    $ sudo mount /dev/sdb1 /mnt/difficultdrive
You should be able then to access your difficult drive.
To confirm that your added drive is at /dev/sdb1 :
ls -l /dev | grep sd
You should see something like
brw-rw----  1 root    disk      8,   0 Oct  3 06:06 sda
brw-rw----  1 root    disk      8,   1 Oct  3 06:06 sda1
brw-rw----  1 root    disk      8,   0 Oct  3 06:06 sdb
brw-rw----  1 root    disk      8,   1 Oct  3 06:06 sdb1
Note that last line.
