If your editor does not provide an option for that you could write a function like that one:
kate~(){ cp "${!#}" "${!#}~" && kate $@ ;}
You can do that for every editor, this simply takes the last argument (${!#}), which always should be the filename, makes a copy of it and runs the editor (kate) with the whole argument line ($@). This example function is called with kate~ [OPTIONS] [FILE]. Functions like that are best stored in the ~/.bash_aliases file, this way they are effective for every new opened terminal.
To test for a specific directory like /etc/ you could do e.g.
kate~(){ [[ "${!#}" =~ /etc/ ]] && cp "${!#}" "${!#}~" ; kate $@ ;}
This way the backup file will only be created if the file to open is located under /etc/.
