I'm using windows currently but because of programming, aesthetics, financial and other reasons I have decided to move to Ubuntu.
Problem is my device is a laptop with Intel CPU and AMD R7 M360 GPU and I have read online (like here) that AMD graphics are a mess in Ubuntu 16.04.
I'm not very familiar with how Ubuntu work or what some of these technical words used in the link above, Until now I have just simply wrote C++ codes in Ubuntu or any Linux environment.
Should I avoid moving to Ubuntu or is there a solution to this driver issue?
Thanks.
Alireza
  • 161
First of all, the article linked to is fairly old in Linux terms and AMD regards.
Ubuntu works very well with AMD hardware, but your use should determine which Ubuntu version you need.
Ubuntu 16.04 LTS (Long Term Support) is primarily for you if you are going to use professional software such as CAD, OpenCL and similar software. AMD provides their own closes-source proprietary graphics driver on their website http://support.amd.com/en-us/kb-articles/Pages/AMDGPU-PRO-Driver-for-Linux-Release-Notes.aspx
However, if you don't know what any of this is, you might as well go with 17.04, since it has a newer kernel and therefore better hardware support - again, however, AMD's own closed source driver doesn't support this newer kernel, so you won't be able to install it on Ubuntu 17.04
Instead, you will be using the Open Source radeonsi driver part of a project called MESA. radeonsi is actually developed by AMD developers, and this is the driver you will be getting the best overall experience with.
The Open Source driver radeonsi is the AMD driver with the best gaming support on Linux and also has no screen tearing. This is the recommended driver for most users.
The only downside of the radeonsi driver, is that it is packaged alongside every major Ubuntu release (every six months). Therefore, you will not be getting the latest enhancements right away.
However, to that, there is a solution. If you want the latest drivers automatically, you can add something called a repository. There is a repository that will automatically update your open source radeonsi driver everytime a new update arrives.
You can do that by opening a terminal ctrl+alt+t (after installing Ubuntu), and enter:
sudo add-apt-repository ppa:paulo-miguel-dias/pkppa
sudo add-apt-repository ppa:kisak/kisak-mesa
press yes to add it and then:
sudo apt update && sudo apt upgrade -y
Lastly, reboot your computer and you will have the latest stable graphics driver installed.
There is only one caveat with adding this repository, which might be that you need to remove it before upgrading Ubuntu to let's say Ubuntu 17.10 when that arrives.
You can remove the repository by writing this in the terminal:
sudo apt install ppa-purge
sudo ppa-purge ppa:paulo-miguel-dias/pkppa
sudo ppa-purge ppa:ppa:kisak/kisak-mesa
s When the new Ubuntu has been installed, simply add the repository again to automatically get the newest updates again. BTW, this repository also works on Ubuntu 16.04 LTS
*radeonsi is also referred to as AMDGPU
** The closed source driver is referred to as AMDGPU-PRO
You can download Ubuntu and try it out on your computer without installing it. You only need a USB Dongle and put a Ubuntu Live-Preview on it.
You can get this here: https://www.ubuntu.com/download/desktop
sleort
  • 448
