15
I am installing Ubuntu on my virtual drive and when I get to the 'Who Are you?' section of the process I am unable to type any text into the boxes.The cursor clicks into each box such as username and password but won't let me type anything therefor I can't proceed and click continue.
I came across similar questions about the who are you? but not about being unable to even type the text in.
Any help would be greatly appreciated.
dlin
  • 3,900
Hackman
  • 151
8 Answers8
21
I just had this issue as well. I'm upgrading from Ubuntu 15.10 to 19.10. I couldn't type anything, but the mouse worked. I couldn't click in the text box, but I could click "Log in automatically" and "Require my password to log in".
I was able to fix this by right clicking on a text box, then click "Insert Emoji", then click a random emoji. Now all the text boxes work and I have no issues.
I hope this helps someone.
I experienced the same problem. I was trying to install ubuntu using Virtual Box and created the empty vm and started it. I was prompted for the startup disk and browsed to the iso. When I got to the "who am I" screen I was unable to enter anything - the controls were disabled.
I did the exact same thing, just instead of supplying the iso when prompted, I inserted the iso into the CD rom before launching the VM. This fixed the problem for me.
Aidan
  • 231
I realize this is an older thread, but thought I'd comment as I just had this exact same issue. I deleted the vm and started over, this time allocating more RAM. I doubled the recommended amount and it worked like a charm.
Melissa
If you are using Virtualbox, power off the VM and change the "Video Memory" under the Display module to 128 MB.
Peter
I had a problem like this. What happened was my window was small, and it was not showing the buttons to go forward. So I TABbed myself out of it. I clicked one field and tabbed myself till I went to the last field. Then I pressed TAB two more times and pressed ENTER and it worked.
I hope this solution helps.
I just randomly copy & paste, then will come out a VirtualBox random text, then I just copy and paste for my password and username.
I had this problem, except that the text areas wouldn't even take focus. The 'insert emoji' trick didn't work -- the emoji were inserted but I still couldn't type anything. Rebooting the VM fixed the problem. This, and the fact that the solutions offered above are all different, would suggest that this is a randomly occurring bug, and that rebooting the VM should be all that you need to do.
I just resolved the issue on my laptop my disabling Hyper-V in Turn Windows features on or off.
