How does one go about getting the command line prompt back after using the systemctl status command? The command appears to succeed as it displays the status information of the requested service. However, the terminal appears to lock up after using the command.
Asked
Active
Viewed 1.2e+01k times
90
If you mean
systemctl status
at the end it shows this:
├─systemd-journald.service
│ └─318 /lib/systemd/systemd-journald
├─fwupd.service
│ └─1703 /usr/lib/fwupd/fwupd
├─systemd-networkd.service
│ └─395 /lib/systemd/systemd-networkd
└─cups-browsed.service
└─2918 /usr/sbin/cups-browsed
lines 172-194/194 (END)
... then press a q for quit.
As steeldriver noted in comments: use --no-pager if you do not want this behaviour see details.
systemctl status --no-pager
systemctl status | cat does the job as well. You're just redirecting the output of systemctl status to cat which in turn dumps everything on the console without any pagination
blueren
- 201
- 1
- 2
- 4
